There is a guy in Australia who built the Z32 with the below specs. If I could, I would love to build the same and see how it does. What do you think? BLACK BEAST (Australia from [ www.aus300zx.com ]) SLICKTOP TT R-SPEC 565RWKW @ 5800RPM - 30PSI 460RWKW &1000NM TQ @ 4500RPM
ENGINE Beast Race Spec Stage 1 SERIES 2 MOTOR
RACE PORTED HEADS CHAMBERS RELIEVED AND BORE MATCHED FERREA 1mm OS VALVES FERREA DUAL VALVE SPRINGS FERREA TITANIUM RETAINERS VITON VALVE STEM SEALS JUN 66 264/9.5 CAMS BDE INTAKE GEAR SPROCKETS BDE EXHAUST CAM GEARS GATES RACING KEVLAR TIMING BELT TOMEI METAL HEAD GASKETS BLOCK TORQUE PLATE BORED/HONED TO 88MM WATER GALLERIES DRILLED/DEBURRED CRANK KNIFE EDGED/BALANCED/MICOPOLISHED CRANK PULLEY & FLYWHEEL BALANCED TO CRANK EAGLE RODS CUSTOM WISECO PISTONS CERAMIC COATED (ALL PARTS CRYOTREATED AND BALANCED) ACL RACE BEARINGS NEW OEM OIL PUMP PLENUMS PORTED/HONED AND MATCH PORTED TWIN K&N XTREAM FILTERS GTX2863R TURBOS 3" INTAKES Z1 58mm THROTTLEBODIES TDMWORKS FMIC + 2.5" PIPING TURBOSMART 50mm RACE PORT BOV's CUSTOM ROSS U/D RACE DAMPNER 4.8kg GREDDY OS RACING PULLEYS BDE ENGINE MOUNTS CUSTOM STAINLESS TURBO WATER LINES TWIN 19 ROW OIL COOLERS -10AN smic locations GREDDY THERMOSTATED SANDWICH PLATE 10AN POWER STEERING 7 ROW COOLER N/A POWERSTEERING PUMP ASI RADIATOR 56MM SZ HIGH VOLUME OIL SUMP CUSTOM OIL CATCH/BREATHER AND WATER OVERFLOW TANK PENRITE RACING OIL PARTS CERAMIC/HPC COATED FUEL
MATTZ TOPFEED FUELRAIL ID1300CC INJECTORS CUSTOM 4 litre BAFFLED FUEL SURGETANK WALBRO 400LPH LIFT PUMP TWIN BOSCH 044'S -8AN FUEL LINE FUELAB FUEL REGULATOR -8AN A1 FUEL FILTER 40 MICRON 8AN ALUMINIUM FUEL LINE AND TEFLON HOSES/FITTINGS ZEITRONIX ETHANOL SENSOR FUEL COOLER FLEX FUEL 98 TO E85 WHEELS
TE37 SUPERLAP 18 X 10 +20 275/35 R888 18 X 11 +18 315/30 R888 BODY JET BLACK MODIFIED 35mm SPL WIDE/VENTED FRONT GUARDS CUSTOM 45mm REAR METAL WIDE BODY MODIFIED UAS/GREDDY FRONT BAR FOR WIDEBODY MODIFIED TWINZ REAR BAR/DIFFUSER FOR WIDEBODY CUSTOM UNDERTRAY FOR TWINZ BAR DIFFUSER STILLEN TYPE III SKIRTS AND DOOR FILLERS BORDER VENTED BONNET AEROCATCH BONNET PINS C/F VENTED NOSE PANEL CUSTOM AIRTRAY GANADOR C/F MIRRORS POWERTRIX FOG LIGHT DUCTS APR GTC-300 1700mm CARBON WING +REINFORCED HATCH CUSTOM FRONT SPILTTER WITH APR SUPPORTING RODS CUSTOM TOW HOOKS SUSPENSION RE TEIN COILOVERS CUSTOM SPEC (ex UAS slotcar) EDFC IKEYA FORMULA FRONT LOWER ARM IKEYA FORMULA REAR LOWER ARM IKEYA FORMULA TENSION RODS TUNE AGENT TRACTION RODS UAS FRONT UPPER PIVOTING CAMBER ARMS DRIFT SPEC REAR UPPER CAMBER ARMS UAS HICAS ELIMINATOR (midori style) SUPER PRO BUSHES diff ,sway bars,steering SPL ALLOY SUBFRAME BUSHES OKUYAMA CARBING FRONT STRUT BRACE SPL FRONT FENDER BRACES UAS RADIUS ROD SUPPORT BRACE STOCK SWAYBARS MODIFIED CHASSIS PIVOT POINTS FOR ROLL CENTRES UAS CUSTOM BILLET TIE RODENDS BRAKES
STOPTECH FRONT 355MM SLOTTED STOPTECH REAR 328MM SLOTTED FERODO DS2500 PADS CHILI MASTER CYLINDER BRACE MOTUL RBF 600 BRAKE FLUID UAS BRAKE AIRDUCTS INTERIOR COBRA SUZUKA PRO GT SEATS COBRA ALLOY SEAT MOUNTS CROW 5 POINT RACE HARNESSES SFI 16.1 APPROVED MOMO COMPETITION WHEEL NRG SHORT BOSS QUICK RELEASE CARBON FIBER VINYL TRIMMING 6 POINT CAMS SPEC ROLL CAGE with full interior AVT RACE PEDALS FIRE EXTINGUISHER DRIVECHAIN
PPG HELICAL DOG BOX PST CARBON TAILSHAFT COMPETITION TWINPLATE CLUTCH MODIFIED STOCK SHORT SHIFTER LEADERS GEARS 4.10 QUAIFE LSD UAS CLUTCH LINE PENRITE GEARBOX & DIFF OIL EXHAUST
MIKE SMITH MANIFOLDS ceramic coated AMS 3" DUMPS ceramic coated AMS 3" TEST PIPES SZ 3" CATBACK -XPIPE WITH DUAL TIP MUFFLERS ELECTRICAL HALTECH PLATINUM PRO HALTECH I/O EXPANDER BOX HALTECH DUAL WIDEBAND HKS TWIN POWER IGNITION ZEITRONIX ETHANOL ANALYSER KIT SSB LITHIUM BATTERY 2.5KG 900CC VEI DUAL AFR GAUGE DEFI RACER 60mm WATER TEMP DEFI RACER 60mm OIL TEMP DEFI RACER 52mm OIL PRESSURE DEFI RACER 52mm EXT TEMP DEFI RACER 52mm FUEL TEMP DEFI RACER 52mm FUEL PRESSURE DEFI RACER 52mm BOOST GUAGE DEFI RACER 52mm VOLTS GUAGE BLITZ SBC DUAL BOOST CONTROLLER POWER ISOLATOR SWITCH
